Engine code identification
Obwonkonobe
AZ
Ethan
C10 custom deluxe
I snagged this pic a while ago, its the front passenger pad that should have the engine code. Although when I try to use typical decoders it doesn't match up. It had goodwrench 350 valve covers when I bought it so I assume its not original. I just wanna be sure its a 350 and see when it was made. If anyone knows what kinda decoder to use I'd appreciate it, but the one in the service manual doesn't match, thanks
78C10BigTen
pennsylvannia
C10 BIG TEN
My bad, service was bad and pic didn't upload
Im no expert by any means but id say that is aftermarket. The factory stamping pad should extend farther up twords the intake and from what ive seen the factory stamping is usually up higher. Such as this...
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Oh weird, is there another location I can check?
78C10BigTen
pennsylvannia
C10 BIG TEN
There should be a casting code on the drivers side rear behind the head but the gives you a year range... the front pad is more specific. Thats how i found that my 350 came from a 73 car not a 78 c10 lol
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Il poke around some more soon and report back, thank you
78C10BigTen
pennsylvannia
C10 BIG TEN
This page may or may not help you isolate what your after. It helped me nail down exactly what my motor was from. Plus helped me learn what the block suffix code and block casting code was
http://www.73-87.com/chevy_ids/sbcid2.htm
Obwonkonobe
AZ
Ethan
C10 custom deluxe
Thanks that site will help. I just tried to check but its too hot. Il get a better look one morning when things aren't hot
78C10BigTen
pennsylvannia
C10 BIG TEN
Its real tough to see when its in the truck...
DanMcG
Central NY
k10 k10
Here's what I found when researching my motor.
1= chevy
M= Mexico
317= March 17
4= year 84?
VP was a Target Master reman block, which is what GM called it before changing the name to Goodwrench. From what I've found the VP means it's a 350 ci 260 hp..
Obwonkonobe
AZ
Ethan
C10 custom deluxe
1= chevy
M= Mexico
317= March 17
4= year 84?
Oh alright thank you, good info
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Brake clean will help to expose what’s back there.
DanMcG
Central NY
k10 k10
Small Block V8 1962-1967 327, 2 bolt?
Obwonkonobe
AZ
Ethan
C10 custom deluxe
From the little I can find mines a mexican reman. Il get to the rear this weekend when its cool
jodygraham64
