E3 Plugs
fowjacob
Lubbock,TX
c3500
383 Stroker
About to do a tune up are they worth the extra money compared to auto lite maybe
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
AC Delco...I think every one of us have had problems with just about every aftermarket plug. Save yourself some headaches...Keep the ignition all GM
Yeah, AC delco. Although I've had good luck with Accel and NGK too.
towman
harrisburg pa
jay
v10
ac delco, ngk, or denso none of them will do you wrong
This reminds me of something that really bothers me. It seems that about any GM vehicle that comes into the shop with an owner-installed tune up has Bosch Platinum plugs installed. Does Bosch own all of the parts store chains or something? Why do they seemingly push those things?
BTW, do NOT run Bosch Platinums in a GM vehicle.
I do nothing but AC Delco on mine!!
Jims86
Patterson,Ca
5.7 TBI
My dont like Platinum plugs in dizzy equipped vehicles.
Back in the day, in our race motors, believe it or not, MotorCrafts were the way to go. AC Delco's fouled out quick, but then on our stockers, AC Delco was the only way to go. Auto Lites seem to run good in the Olds and Big Block Ford though. You'd think a spark plug is a spark plug, but nope, not true. It does matter. And for your stock or mild motor, I'd agree go AC Delco. I've always had good luck with Accel or MSD cap and rotors though WITH A STOCK COIL.
fowjacob
Lubbock,TX
c3500
383 Stroker
thanks guys lots of help
Don't thank this will matter but she has vortec heads just in case
plug wires? if this question need to be on another thread please tell me
I'd go AC Delco wires too. You get what you pay for in wires. Pay the bucks, they are good, get cheap wires, you get cheap wires. Can't skimp on wires. Accel wires aren't bad either, but don't get the kind you cut and put your ends on, unless you are good at it and know for sure what you're doing. And do not get solid twisted wire or your stereo will sound like ****. Go with Carbon Core.
fowjacob
Lubbock,TX
c3500
383 Stroker
Was in oreillys the other day and over heard the salesman or what ever you wanna call him, recommending the plugs.
fowjacob
Lubbock,TX
c3500
383 Stroker
what do you recommend the regular, platinum, double platinum, iridium.
gap .45 i guess
Jims86
Patterson,Ca
5.7 TBI
Just make sure you use the correct long reach plugs.
Its your thread...ask away.
wheelerboy12
Dundee, OR
jeremy
gap .45 i guess
regulars are cheap! like 15 bucks for 8 and they have a rebate right now for 50 cents a plug and even more on the upper levels iridiums run the best but it really dosnt matter if your motor stock
as far as wires go autozone sold me duralast and they have been great so far.
I believe this has to do with profit margin. The chains make more profit per plug than others. I was told that at AZ once when they were trying to push oil filters. They'll push the higher profit margin items.
ksquare84
