Dual tank 87
87scotty
Central il
Andrew
V20
5.7 for now
Having problems when i switch tanks! Runs like crap spittin and sputtering sometimes kills the motor. But if i do get it going it comes out of it!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Is it switching to a particular tank, or does it do it for switching to either one.
87scotty
Central il
Andrew
V20
5.7 for now
Originally i thought one. but now im thinkin both. wondering if the electric valve isnt havin problems i can rev it up to leep it running. But it wants to sputter out if i let off tje throttle
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
If you isolate it to one, I'd check the pickup in the tank because it may be inundated with crud. If it does it with both, I'd check the wiring to the switch valve, and if it looks good, I'd replace the valve.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Try bypassing the valve and go straight to one tank. See if that fixes your problem.
Actually, the rev-up part actually makes me think you have a weak fuel pump.
87scotty
Central il
Andrew
V20
5.7 for now
Ill get it switched over to the other side run it till its running good try switchin it over been like that awhile just now startin to drive me nuts.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Oh, yeah. I didn't even notice this is an '87. I'd absolutely keep the fuel pump on that tank in mind.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Very common for the hose between the pump and the sending unit to split. You'll get enough fuel for it to stumble and run like garbage at idle, and not much else. It just pumps the fuel right back into the tank.
87scotty
Central il
Andrew
V20
5.7 for now
Switched it on the way home and it was fine. let off the throttle at 45 switched it no problems ran the same
83C30dually
