Dual front shocks
wagonman
Elmira Oregon
george
k1500
Howdy guys,My 85 swb 4x4 has dual frt shocks.Was this factory installed,it looks OEM.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Hotrod Pc has the same truck as me expect his has the dual shock front end, OEM. It was an option I read about.
I added factory dual front shocks to my '88, the ride didn't seem to change one bit. I think they look cool though, lol.
They are often called "Quad shocks" btw.
towman
harrisburg pa
jay
v10
have had a couple without the quad shocks and they rode the same as my 87 with the factory quads, i do think they do help a little when i hang the plow on the front of the truck though
cupp_cody
oregon
cody
k5
The factory quad shocks aren't really a difference over the single my 88 has quad shocks and it's not a whole lot stiffer. But if you go a head and buy some nice shocks for it then there a lot stiffer. I notice it more when im on a gravel road.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Cody, your avatar is afu.
animal
Lee
c10 silverado
350ish
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Gecko tires?
Yep my 85K1500 is OEM dual shocks. They need replaced but nonetheless they are there, and Retro has the right RPO code for them too.
attachment.php
attachment.php
wagonman
Elmira Oregon
george
k1500
Hey Hotrod was reading you build sheet and am jealous.Wanna trade your 373 diffs for my 273s,you will get better mileage?? But you wouldent be able to pull a sick ***** off a piss pot..
Ohhhh helllllllll NO. :roflbow::roflbow::roflbow: Nice try homie, but no thanks. I wanted 3.73's real bad, and when I seen this truck had 3.73's on the RPO sticker when I went to look at it, I think I may have came just a little.
My other truck, the 85K10 has wussy wagon 3.08's in both axles. I have a 4.10 and a 4.56 14b FF rear axles, so which every front 8 lug I find first, either 4.10 or 4.56 that's what that truck will get.
I'm not so sure I buy that mpg with taller gear BS anyway. There comes a point when your rpm is to low and you are below your economy or power band and hurts worse than it helps. Also, the taller gear strains a bit even the rpm is lower. My dads truck has 3.23 gears in it. He gets the same mpg as he did with 4.10's in it, but lost pep off the line. He also gets the same mpg using 4th gear on the hwy at 70, as he does using 5th OD on the hwy at 70.
wagonman
Elmira Oregon
george
k1500
Knew you wouldent bite,neither would I.
tweeter68
