Drive shaft lengths and questions
American_justice
Kerrville tx
Levi
So I have a 83 long bed custom deluxe and my tranny went out. The turbo 350 I had in it before had a 9 in tail shaft length but I have another one I want to put in it that is a 6 in tail shaft. I know the drive shaft won't work for it but I'm wondering if they even made a drive shaft with this configuration and length in a stock vehicle. I know I can make one custom or have one made but it would be nice if I could go rob one off an old junker or something. So I need a lwb drive shaft that will go to a 6in short tail shaft tranny. The one I have for my 9in is approximately 71 in long. It will have to be longer than that for sure. Anyway thanks in advance
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
SquareRoot
Is this a 2wd I'm assuming? A 71 incher....wow! Do you know the diameter of that beast?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
My 1970 c10 longbox came with 6 inch tail shaft th350 and had a two piece driveshaft with a hanger bearing right behind the cab.
Not sure if the squares had two piece driveshafts unless it’s a crew cab or a cab and chassis truck. My 77 c30 cab and chassis has a two piece driveshaft but the thing has a crazy long wheelbase
Craig 85
Nashville, TN
454/TH-400/NP205
I had always heard 72" was max. I did some research and found a 2009 Suburban 2500 with a 78.36" rear drive shaft. It is a 4" diameter with .087" wall thickness. In reading the Dorman description, it includes the slip yoke, so I'm assuming this total length includes that.
There is a shop in San Antonio called Driveshaft Specialists, and they had no problem making a new front driveshaft for my K25, just based on the year and model of truck. My front driveshaft has a cardan joint (universal joint), slip joint for length, and other features, and they got it all right. You might give them a call and ask for recommendations on what to do with your truck.
I had the work done about 15 years ago, but maybe they still have some old guys who understand the best solution for a squarebody.
Preston
Mechanicsville VA
Preston
Good luck been there done that, what I saved on the transmission I spent on the driveshaft plus. I put a th 400 in my long wheel base Silverado. Moral of the story fix the transmission. I ran into other issues with the kick down switches, don’t get me wrong the 400 shifts great but I just didn’t save any money making the swap from 700 to 400. I do believe GM did go to 2piece driveshaft if it was over 72” long
Preston
Mechanicsville VA
Preston
Welcome to GMSB from Virginia
PS you could also swap the tail shaft
GustavoG
snyder
gustavo
Chevy
350 v8
I put a long tail th400 in my 84 c10 also long bed and I need a sorter one because the one I have is to big is also a 71 inches one so I think they did not make the th400 for c10 unles that’s what I think
tweeter68
