Door needs tweaking
Norwester
Battle Ground, WA
C-10
The doors on my 86 fit pretty flush except for the lower rear corner of the driver's door. It sticks out from the sill may 1/4-3/8"
An old motorhead told me he's adjusted many doors in his past by inserting a short length of 2 X 4 between the jamb and the door and then applying pressure against the part of the door sticking out....essentially warping it slightly.
Sounds extreme to me......does anybody know of this method?
Is the sheet metal so thin that it'll easily warp a bit?
yevgenievich
Viktor
sad
very sad
less sad
It should work, that was the method i used to straightened the tail gate
Georgeb
Wisconsin
George
K10 Burb Z71
That will work. Done many times.
Norwester
Battle Ground, WA
C-10
I know its a subjective question but would it take a great deal of force to move it a 1/4" or so?
Georgeb
Wisconsin
George
K10 Burb Z71
No, not really. I would gently push then check then push then check untill it's there. You may need to increase the force as needed to make it move. You will be suprised how far you can move it.
mbl530
new york
michael
350 ci 375 hp
You would be surprised how many times at the factory that the 2x4 method was used. I knew a guy who worked at a GM plant, and doors were adjusted that way far more than we know.
Keith Seymore
Motor City
Keith Seymore
4.3L
Your friend would be correct.
The fenders were adjusted that way, too.
K
K5Chris
