Door lock is stuck
sonicbluezx3
North Carolina
Steven
I recently replaced the door locks (where the key goes in) and the exterior door handles on my truck. Everything worked fine when I tested it. Now I go back a month later after the truck has been sitting with the door unlocked since it was in my garage. I pulled the truck out to work on my car and parked the truck outside and locked both doors. I came back about an hour later and tried to unlock the door on the passenger side.... and it wouldn't open with the key or by pulling the inside knob up.
So after yelling at it for a few minutes :gr_guns: I pulled the door panel off (hard to do with the dang door stuck shut) thinking that I could get it from inside the door. Nope... got nothing. I sprayed some PB blaster on everything in there and still got nothing.
So what the heck happened?? Any clues on what I can do?
Did you try pulling the knob up or is it power locks?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Reading>you, buddy.
I would pull the lock cylinder and see if it's still stuck.
sonicbluezx3
North Carolina
Steven
I disconnected the lock cylinder to see if that was the issue and it still wont work. Wondering if the latch is putting pressure on it keeping it from unlocking
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Chinese knock off aftermarket crap again I bet. You'll probably have to take the key latch out to get them to unlock again.
sonicbluezx3
North Carolina
Steven
I ruled the key latch out though... I disconnected it and tried to unlock it and it still wouldnt unlock.
Carb'ed Vortec 350
Mine does that. I have to push the outside button in as if I am opening the door, for some reason that disengages something inside the door and I can then use the key to unlock it. And out of curiosity I tried pulling up on the inside knob without first pushing in the outside button, and it wouldn't unlock. Push in the button and it unlocks like it's supposed to.
Yes, if the button happens to pop out too far, the door will not unlock. My '88 Burb has had occasional troubles with this since I have had it. I had planed on buying new handles for it someday, so much for that!
sonicbluezx3
North Carolina
Steven
I haven't been back out there, but I'm going to try that tonight. The stupid thing about it is that I changed the handle. I had to put the old pin back in since the new one wouldn't fit, but I don't see how that would have changed anything... the pin just holds it in place.
sonicbluezx3
North Carolina
Steven
Okay I went out today and pushed in the button on the exterior door handle and tried to unlock it, and still got nothing.
So where should I look next? I'm starting to get pissed off with this truck... put so much work into it and I get these stupid problems.
A couple times recently, the Burb's RR door has got stuck locked. IIRC, something in the latch was hanging up because it needed lubed, pulling the inside handle repeatedly (and quickly letting go) freed it up so it could be unlocked. It hasn't done it since then, but I think that's what I did.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
flip the inside door handle a couple times. my wrecker does this once in awhile. also make sure the outside button isn't sticking in some.
sonicbluezx3
North Carolina
Steven
Okay finally got this resolved. My buddy who can fix anything came down and checked it out and lo and behold... 5 minutes later knew what the problem was. The button inside the new door handle needed to be trimmed down some. Trimmed it and it's fixed.
So now I can put the interior back together! Ha.
78ALB
