- May 18, 2020
- Washington
- Todd
- K20
So but of a different issue.
What I do know:
I understand how the circuit works for the dome/courtesy lamps.
They worked with Headlight light switch But door jamb switches were non op. Those have been replaced and are working. Headlight switch replaced as well, as it appeared to contribute to the issue
The circuit gets a random “partial” ground short somewhere in the wiring. IE dome lamp will light up at half brightness without being activated by any of the 3 switches. Then full ground if switches are activated.
Tells me there is a “Live” short in white ground wire somewhere. IE ground wire is grounding somewhere it shouldn’t. However this is not intermittent. It may be shorted for days( consistently) and then work fine for days (consistently).
I’ve been able to move, wiggle or verify the wires coming from the dash thru the drivers door sill and up to the dome light. They’re in tact and or don’t cause a change in condition when pulled or moved around.
I have not been able to locate the wire from the Passenger jamb switch but have pulled on it thru the door jamb with no change in condition.
At a bit of a loss. No wire damage in the “typical” areas, and generally the wiring and systems are very clean on this truck.
Suggestions?
What I do know:
Suggestions?
