- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I couldn't wait for a whole tank so I fueled up at 163.5 miles and got 16.8mpg. It's not that great but is in an improvement over the 13-14 I usually get. There has only been one driveability issue that I've had a couple of times. When idling with the a/c on and max blower in gear the idle has dropped so low that it died. I can deal with that. The funny thing is that I had an '87 burb years ago with the same engine/trans/gearing and it would regularly hit 17 on all 8.
You can rectify that AC idle issue with a High Idle solenoid that is set to get power when the AC compressor kicks on then it raises the idle about 200 rpm. Do you think it would have done better without the AC running? I'd imagine that AC compressor would bog it down pretty good.
