Differential setup
Scott Vincent
Sierra Vista, AZ
Scott
350 B30over
Hey fellers...need some insight and opinion here...take a look at these pics and you fellas tell me where you think I'm sitting. Backlash is already at around 5 thousandths...just trying to get contact pattern in the green.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
look good to me...on mine i backlash at 7 thousand
Looks like it "might" be just a touch deep into the tooth, but kind of hard to tell with the thick marking paint. In my unprofessional opinion, I'd say it's good.
Loco Hills
K-30
I like it.It needs to have more resistance as you turn and check the pattern.
Even with 5 thousandths of backlash,you have to put out.Leather gloves or a rag.
Loco Hills
K-30
Janz Engineering on YouTube.Master of ring and pinion.Even the pro racers and rock bouncers use his methods
Turbo4whl
Downingtown, PA
Wayne
Jimmy
This is very important. You must add a load when checking the pattern. Another way to achieve this is to take a pry bar between the gear housing and the smooth side of the ring gear. Turn the pinion nut with a wrench, making sure you are rotating the pinion gear into the drive side of the ring gear.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
^^^^ This
It’s hard to get an accurate reading without simulating a load on the gears. We tap a punch in between the edge of the ring gear and the diff housing at top or bottom depending on which direction it is rotating. Be sure to run it through in both directions so you can inspect the drive and coast side. I’ve had to compromise on patterns based on drive Vs. coast pattern to keep them both acceptable.
You can also thin the patterning paste with a little bit of ATF so it isn’t so thick.
Just as important as “where” the contact patch is, is the “shape”. It should be a gentle transition from where the gears first connect to where the paint is totally wiped clean. There shouldn’t be any real sharp lines at the leading and tailing edges.
How can y'all tell that he didn't put a load on it as it was rotated?
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Where the OP put the marking paste, the pattern should show as the metal gear. All the paste forced out exposing the gear tooth. Instead you are seeing the footprint of the paste collected on the pinion gear.
Loco Hills
K-30
Jantz Engineering,I apologize.His channel has a videos that explains exactly where you want your pattern.
@bucket,I can see that real pressure wasn’t applied to the marking compound by how faint it is.
Someone mentioned thinning it out,and that’s exactly right.I learned this later after setting up a couple gear sets.
The bigger axle assemblies take quite a bit of resistance to see a good pattern.The last 14 bolt I did,I used a plastic hammer to pry against the ring gear.
This job is so much easier with 2 people.
Scott Vincent
Sierra Vista, AZ
Scott
350 B30over
Ok...well considering that Iʻm a rookie in this realm...it sounds like most of yaʻll are saying I should clean off the existing compound, buy some new compound, which apparently Iʻm gonna have to go through Amazon to do instead of being able to get it today :(, thin out my compound with ATF, and run a new pattern with some type of resistance to the gears. Is that right?
I mean with what Iʻve got right now am I good? Can I run this without issues? This part is a little more intimidating than I expected and I was really hoping it was good.
And I just started finding a bunch of stuff for making my own compound...is this safe to do?... because if Iʻm gonna do this Iʻd rather make my own instead of paying $15 for 1 oz. of this ****.
You haven't changed any settings, so maybe just apply pressure and run it again? I haven't checked the pattern on much stuff either, so maybe that won't get a cleaner result.
CalSgt
CA
Casey
I’m assuming you used all of the marking compound already…
Take the brush and smear the pattern marks over with the stuff left on the ring gear.
Yes you can make your own too, I think we used some titanium dioxide (white oil paint base) and just thinned it down. It’s thicker than bearing grease otherwise.
ETA: you don’t HAVE to thin the marking paste but it makes it go farther and easier to use
Scott Vincent
Sierra Vista, AZ
Scott
350 B30over
Set it up the same...thinned it and added resistance for better marking...here's what I got. Tell me what you guys think now.
guillermoariast
