different diesel swap like CAT or Detroit
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
That thing is awesome.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
The truck is nice, but what do I have to do to get a spread like that!?
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
the 6v53T which is a 2 stroke which has a turbo and blower from factory is pushing 233hp @2500 rpms and 489 ft lbs of torque @ 2500 rpms the only problem the motors are expensive if your looking for a remand or even a used one
cumminsedge
Tucumcari, NM
Wesley
Your other problem with a detroit 2 stroke is that they make no power on the bottom end. If you drop em under about 1200 rpm under a load, you have a good chance of sucking the seals outta the blower as well. We have a old international dump truck at the mine with a 6-53, and a huber road grader with a 6v72. There is a reason they call em the screamin jimmy. Ya gotta keep em wound tight to make that power.
As far as baby motors go, you might check into a John Deere unit off a small generator. We have a couple of those as well. Prolly only about 200 horse or so, but both of our gen units at the mine are now over 20K hours with only a water pump replacement and regular oil changes every 300-350 hours.
The Cat 3126 is a good motor, but they are low power, high torque motors. They work great in the 4500 and above series trucks, but you'd have to check the weight to see if your front axle can support it. Probably about the same problem you'd have with swapping in a 8.3 cummins.
Regardless, if you can get adaptors made to work, you would definately have a heck of a one-off truck with any of those motors. I like the 5.9 cummins because of parts availability and it has a very wide powerband for a diesel.
Jims86
Patterson,Ca
5.7 TBI
Have you guys seen the youtube videos when those things run away after sitting for a long time? Funnier than **** seeing people run away while shitting themselves,then some old guy comes in and starves it for air.
cumminsedge
Tucumcari, NM
Wesley
Most of the 2-strokes have a emergency kill cable that goes to the supercharger. Flops down a door doing the same thing, just starves it for air. Again, it can suck the seals outta the blower, cause the motor is going to try to pull air any way it can.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Yeah, that was an old GMC. There's a few more vids of run away diesels as well including a UPS truck.
87sierra
Pennsylvania
Sierra 2500
5.7L 350 TBI
I was just looking around on the web and found this truck which makes it seem even more possible to fit a CAT engine in a square the 3208 weighs about 2080 lbs its L58in.x W38in.x H36in. http://www.youtube.com/watch?v=MOWAati5Pm8
cartunesguy
