Cruise Control
ryan427
Ryan
It's.... not working. Vacuum is good so I think it is the cruise control "unit". Just wanted to know if anyone knows of common problems. Just replace the control unit and presto?
You check the fuse? We do need a good tech article here how to troubleshoot them, unless it is already buried here somewhere. Also the wires in the T/S stalk can break where it pivots.
Mine is broken on the resume/accel button. :shitsweak:
Guardian
Jeff
c 10
Check the fuses first, always. The most common that I used to see was a bad fuse of a bad brake light switch.
ryan427
Ryan
Thanks. Is there a fuse for the brake light switch? Or did you mean to say "a bad fuse OR a bad brake light switch". Sorry... I'm learning so not quite picking up on everything quite yet. I can pull all of the fuses and check them either way. Good advice.
oneluckypops
Sedalia, Mo.
Luke
The switch has 4 wires that go to it. 3 of them go to the cruise control module, the other 1 is a power feed wire from the ignition hot.
Colors of the wires are:
Blue, Which is the 12 volt power supply from Ignition Hot.
Green, Sends 12 volts to the cruise control Module when the switch is in the on position. (cruise Input control)
Red, sends power to the cruise control module for the "set/coast" function.
Yellow, sends power to the cruise control module for the "resume/accelerate" function.
Color coding is for the harness on the switch itself, Vehichle harness may be of different colors. Also note that the harness from the switch is encased like an extention cord, so to test them you would need to peel back the outer casing.
But like was already mentioned, check fueses FIRST anf formost.
ryan427
Ryan
Thanks oneluckypops. Great tech info. Will follow your advice and report back.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Mine wasn't working when I bought the truck, didn't really care because I don't use it, but while fixing something else I noticed a tear in the cc diaphragm. This is what it looks like. Replaced it and it works fine.
My '84 had the button on the end of the stalk pop out. I was selling the truck and had to buy a new multi-function switch. (Expensive little sucker, currently $134) I couldn't figure out how to install it though, it involves taking the steering column apart so I tossed the new part in the glove box and told the new owner about it. If someone gets into installing one take pics and do a write-up.
ryan427
Ryan
Good deal. How much was the part? Can you replace just the diaphragm or is the cc unit all packaged together? I'll check that while I am checking the brake switch and fuses as I was advised.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
The diaphragm comes attached to some sort of electrical component, Rock Auto lists it as a cruise control servo. The rebuilt part is $75, a new one is closer to $300.
lusktommy
Tuscola, TX
Tommy
5.7L (350ci)
I have to change mine soon in my 84 ill upload some pics and do the write up on it no problem
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
CFM didnt send you the spacers for your throttle bracket?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Lol, I knew someone would comment on that and my money was on you Jim. The spacer on the truck right now is some no-name unit that a guy over at Pirate sent me for free. (Winning!)
The Super Sucker was purchased after that from craigslist but there was nothing included for the cable. My little Macguyver bracket seems to work fine so no plans to change it.
Jims86
Patterson,Ca
5.7 TBI
Right on!
aaron06
