Cragar S/S wheel lug nuts???
ProStreet83C10
Mason City, Iowa
Hey guys, i picked up some used Cragar S/S wheels - without lugnuts, and id like to know which of these lug nuts my 83 C10 takes.
Not sure what all this means haha
.800 SHANK MAG STYLE LUG NUTS & WASHERS - 5x4.5, 4.75, 5 BOLT CIRCLE
27721-4 7/16 RH with center hole washers .684 Diameter
27723-4 1/2 RH with offset washers .684 Diameter
27727-4 1/2 LH with offset washers .684 Diameter
27780-4 1/2 RH with center hole washers .684 Diameter
27792-4 7/16 RH with offset hole washers .684 Diameter
27846-4 14mm-1.50 with center hole washers .750 Diameter
27732-4 12mm-1.25 RH with center & offset hole washers .684 Diameter
27733-4 12mm-1.50 RH with center & offset hole washers .684 Diameter
J Knight
Baytown TX
82 Chevy
350ci
Should be 27723-4
Evans Ward
GA
Evans
Sierra Classic 1500
Would that part number be the same for an 87 truck with Cragar 610G SS wheels.
Swims350
Logan WV
none
not sure what lug nut size these truks use but you definately want the offset washers because of the 5x5 pattern.
Evans Ward
GA
Evans
Sierra Classic 1500
Had the new wheels put on today at tire shop with conventional lug nuts. Truck rode like a worn out wagon! Going to Summit Racing tomorrow to talk with reps there and purchase the correct Cragar lug nuts. Cragars are 610G SS with correct 5 on 5 bolt pattern, +00 offset. Lug needs a shank to cover wheel stud and secure properly. I think this stud also uses an offset washer.
If anyone knows for sure, please reply. Thanks in advance!
Swims350
Logan WV
none
if your wheels do not have the unilug hole all you need is a reg. washer, the offset washers are to cover the oblong holes in the unilug pattern wheels.
btrain04
