Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
Stupid question: 5.7's oil pan bolts....1/4-20's on the sides and 5/16-18's on the 2 fronts. Did this ever change (such as with the later 350's)? Like to metric?
I had to pull my oil pan - no oil in the motor so was a quick and clean process. Bolts coming out and going back in were not the smoothest. Sounds nuts, just almost felt like when you have a close fit between metric and SAE. One of the 5/16's had alot of shavings on the end - like the shop that built it didn't blow the holes out completely.
Probably not a big deal but my OCD wants to pull it again and clean / run a tap in each hole til it is smooth. Will never be easier than now to do it. Gasket is a silicone 1pc so wont lose it either.
