correct 1 piece gasket to use?
olnick
Milford NH
Nick
c15
1982 350 4 bolt mains
I have a 1982 SBC with the thick timing cover gasket and dipstick on the psg side. I cannot find a 1 piece gasket to do the job! I tried one of the Felpro that have two oil holes on the same gasket and there is NO way it will seal on the opposite side! any suggestions??
Thanks
Olnick
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Opposite side of the dipstick orrrr?
I've installed a few of the FelPro gaskets that were the 1-piece type. They fit well.
olnick
Milford NH
Nick
c15
ORRR: opposite side of the block. DRIVER SIDE It doesn't have a boss extending out to support the additional hole in the gasket. Any part nos. Would be very helpful
Thanks
Olnick
Rickf
Grafton NH
1974, 1954 & a 1937
What manufacturer and part # have you tried?
olnick
Milford NH
Nick
c15
Felpro os34510T This is the one with two dipstick holes and does NOT seal on the Dr side rail.
The felpro 1881 would work?? but is cut out for a stroked block removing 1/3 of the sealing surface, not good in my eye.
The one I just removed (Black silicone rubber) has "NPC1" "MN3981" cast into it. I installed it 5 years ago but never wrote down the mfg/part #. It has been leaking at the lower center of the timing cover the last couple of days the oil has been pouring out ? It is a GM full welded timing cover the bolts were NOT loose, the gasket looks like new??? There is a slight scuff mark on the pan that removed the paint where the gasket made contact! (Dr side of center.)
I would settle on another black gasket same as I now have if I can locate one
80BrownK10
Greenwood, SC
Nate
Thanks
Olnick
I have an 80 truck...motor not exactly sure but think it's older?? Anyway I have a passenger dipstick. I just put in a few months back a felpro one piece gasket. It has two dipstick holes...one on each side of the block. You oil pan has a simple in the driver side to make up for no dipstick on that side. Fits fine, and no oil leaks other than from up top now, out if valve covers.
80BrownK10
Greenwood, SC
Nate
Have you looked at Rock Auto useing your correct engine info
olnick
Milford NH
Nick
c15
Solution found! ! ! ! After three days I was able to finally fix the leak at the timing cover to pan joint! I was able to get a good part # for the 1 piece gasket with the one needed hole for the Psg side dipstick. Its an "Engine Tech" part # OC350-R this is only for the Right hand dipstick block!
My fix using the old Original (installed in 2016) engine tech gasket: I installed the pan without the gasket, However I added washers to replicate the thickness of the installed gasket. Mine measured .145 in.
With the pan installed, I was able to measure the distance from the front lower lip on the pan to the bottom of the timing cover sealing surface. Mine was .589 in. at the bottom most point. Minus the .145 in. spacers leaves .444 in.
The front THICK gasket measures .430 in. This is shy by .014 in. to be able to compress the gasket at all!
To remedy this I took a 2 1/2 in length of "China wall" gasket and tapered down both ends by 1/4 inch The thickness is around .125 in. I weather strip glued this piece onto the bottom of the timing cover sealing surface. I then installed the pan with the old gasket.
I then pressure test the crankcase at 4 PSI I block off the PCV and breather holes then use the dipstick tube to apply the air. I had ZERO leaks around the oil pan not even a slight whistle! THe Dr side valve cover was another thing though!! after a replacement there all is well again!
I hope this might help someone else in the future with a "can't fix it leak" in that area.
The real culprit ended up being the Aftermarket oil pan! The correct opening at the front of the pan is supposed to be 2 7/16 (2.4375) inches. Mine measured 2 1/2+ (2.509) for a difference of .0715 in. This was the reason for adding the amount that I Did (.125 in.)
Olnick
TBSS GUY
