Column shifter linkage
Newc10owner
could some please provide me with a pic of Column shifter linkage for auto trans. I have a 85 Sierra. I need pic where it connects to trans ear
MikeB
North Texas
Which trans? I can take pics of my TH350 linkage, which I think is the same.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Is it a TH350 or 700R4?
74 Shortbed
They all have the same setup at the tranny.
Newc10owner
What about where the bar comes down from the column and meets the bar going across. Is there a screw that holds the bar coming down from the column? Will the universal linkage kit replace all of this?
74 Shortbed
There are variances but this is typical..
Newc10owner
Can I buy just this piece
74 Shortbed
I'm sure you can, but the junk yards are full of them, that is a common part on most GM's, I may even have a few laying around in the pile.
73c20jim
Tombstone, AZ
There is a wave washer under the head of the bolt. I'm guessing its to let the bolt wobble a little in the arm? Or should it be tight and the wave washer is to act like lock washer????
It's there to give the rod some free play for movement, but keep the connection from rattling.
yevgenievich
Viktor
sad
very sad
less sad
I have the parts from 89 suburban
Dale Downes
