Clutch Types, Z bar manual and Hydraulic
Anyone have pictures of their clutch linkages and components? Pedals too? It would be great info for those who are doing manual trans conversions. :wave:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I'll get some of my z-bar setup tomorrow
Cool, Thanks :waytogo:
Here are some stock photos of parts I 'm looking at on RockAuto.com
I'm using 85 K10 w/ 350 motor to get these part #'s since I know 85 used a Hydro Clutch. I'd still like to see pics of them installed so I get an idea of where they go on the firewall and what they look like in the bell housing. And obviously I'll need to acquire a fluid resevoir too.
Slave Cylinder
Master Cylinder
Pic of Clutch master location on the firewall for hydraulic clutch.
attachment.php
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Ill have to see if I can remember to take my gm parts catalog to my parents and scan the exploded view of the z bar setup.
That would be awesome. :waytogo:
crazy4offroad
Curt
K-10
350/SM465/NP205
Some pics of my z-bar linkage, and header clearance...
attachment.php
attachment.php
attachment.php
attachment.php
Ahh OK. There is an assload of room with the Z bar that far back. I'm thinking of my 64 GMC. The Z bar pivot ball actually is threaded into the block. If you've ever wondered what those 2 holes are on the driver side of a Chevy block, it's 2 different holes for the Z bar pivot ball. In this case, the pivot ball is actually behind the block on the edge of the bell housing. I thought I seen that on a manual bell housing pic.
Great pics!
bluex
Spartanburg SC
C15
Does anyone have a picture of a hydraulic pedal assembly outside of the truck?
I have some of the mechanical pedal setup somewhere, I'll try to locate an post them....
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
1985-91 Hydraulic clutch pedal assembly.
bluex
Spartanburg SC
C15
Here are the two mechanical pedal pictures I had.
friscobob
Sutherlin Oregon
Bob
C 10
Anyone got a pic of a z-bar out of the truck, 81 short wide C10 in this case? I have something out of whack on mine. The short rod to the clutch arm runs off at a funny angle, inward and down, just doesn't look right. Clutch arm too short or arm on z-bar too far from bell housing. everything new except the z-bar itself. Wondering if the z-bar I have is from another Chevy altogather.
Thanks, Bob
Heavychevy79
North carolina
Elliott
I got a couple questions about this setup.
Is there a difference between the pedal assembly for a hydraulic and a z bar?
And is there any way of telling exactly where the clutch master cylinder is supposed to be located?
I converted my truck to a 4 spd with hydraulic clutch, and I've had no luck at all with it since I did the swap, I've gone through a couple clutch master cylinders because the rod from the clutch pedal to master keeps bending right in the middle. I'm not sure if there's supposed to be a certain angle it's supposed to be at, or there's something else completely out of whack. I NEED HELP!
I am almost certain the pedal assemblies are in fact different between z bar linkage and the hydro clutches.
It does sound as if you might have the hole for the clutch master misaligned. I was hoping someone could make us a template or give us measurements to make our own so we can drill the hole in the correct spot.
86sunnyguy
