Chrome side molding
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
I getting ready to order some chrome side molding for my truck from LMC. Was wondering if anybody had any tips and tricks, as to getting it on nice and straight?
PTNOUT
Marietta Oklahoma
Dustin
1500 silverado
Never put this on, but had a vinyl letter businesses and did several police units with stripes. We always attached a string from back to front and used it as a guide.
Skweegle89
Oklahoma
Measure off the body line. The string tip, or tape will work too. I have done some pin striping and as long as you stay true to the body line it will be fine.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
String a line and use 1" blue painters tape. Apply the chrome trim along the blue tape edge.
BiggG74
Pasco Washington
Gilbert
GMC
Doesn't the moulding just follow along the body lines?
BiggG74
Pasco Washington
Gilbert
GMC
I guess the hard part would be drilling the holes for the clips to go in but if you made a reverse template you could probably do it.
Skweegle89
Oklahoma
The trim from LMC doesn't have clips. It's just sticky.
VAL
TUCSON, ARIZONA
VAL
K10 SILVERADO
The corner trim pieces, right under the tail lights are the only ones that cave clips. I put in my order with LMC, later today/tomorrow I'm gonna do the painters tape across the body, and see if I can get it on straight.
Yeah use the painters tape method. Crooked molding will stick out like a sore thumb. What are you going to use to cut the molding at the door/fender/bed joints? I see sometimes they are cut on an angle, like a 45*.
BrianGarf
