Cheap radio
dvdswan
Port Orchard, WA
Dave
I found a 1978 Olds Delta 88 in a junkyard with the premium radio of the time AC Delco AM/FM Stereo Cassette 4 channel radio. Bought it for $10. I cut the plugs that go to the radio with 6" of length on them. Installed it and plugged in my single speaker for the moment and it made a huge difference. Best part its the same size as my original AM/FM non-stereo radio. Bolted right in.
73c20jim
Tombstone, AZ
Compare GWH341 to the back of any radio you are considering. In some catalogs they use that number (or equivalent) as a 73-87 model some list as a 77-90, 78-91 etc. I used the female version of that plug for my 91. Is using a later model shaft radio acceptable being its not "correct"? Being that you have no wiring you are in control here.
https://www.ebay.com/itm/Chevy-OEM-STOCK-Radio-WIRE-HARNESS-PLUG-1973-UP/110705534429?fits=Year:1973|Make:Chevrolet&hash=item19c69065dd:g:XRwAAOSw2GlXDYPy
Ordered it.
CookieSoup
Seattle area
Suburban
if you wanted an OEM radio im pretty sure i still have mine
Rusty Nail
Rusty
350sbc
Them old Deltas are the shizznit!
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
Crispy, thanks for the link. I, too, am looking for the same cheap radio but since my wiring harness is all butchered I went ahead and ordered the plug assembly. Since I'm determined to get a stock radio at least I can wire this up ahead of time. Thanks again! trukman1
Crispy
Carbon County, Pennsyltucky
Suburban V1500
No problem at all. Glad it helped. :happy160:
73c20jim
Tombstone, AZ
Still need a cheap knob radio with AM/FM. @CookieSoup
For a 1973 C20.
Thanks guys,
73c20jim
Tombstone, AZ
Bump, 'cause I really want a OEM cheap radio - with FM.
crpntr78
Missouri
I have one , it's an AM/FM cassette form a 1983 C20. Would that work for you?
73c20jim
Tombstone, AZ
73c20jim
Tombstone, AZ
I know Jack **** about radios.
What's the difference between 8 ohm and 4 ohm speakers?
Which would I need for OEM radio?
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
Should be 4ohm. 8ohm is for your home stereo speakers. Car speakers are 4ohm.
idahovette
Weiser Idaho
Perry
K20-K10
Got a GM AM/FM supposedly 78 Caprice. States on the top, stamped into the steel cover "DO NOT OPERATE WITHOUT 8 to 10 OHM SPEAKERS" Also GM part # 16001650. So if you are looking for speakers you better be sure to get what matches your unit.
73c20jim
Tombstone, AZ
Now I'm confused.
jerdanwey
