Camshafts
mybabyk5
Colorado Springs
I need some opinions about what kind of aftermarket camshaft and components I can buy and what performance I can get out of it on an 87 tbi 5.7
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Do you plan to get the computer reprogrammed?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
I would recommend working on your throttle body first, like the ultimate tbi mods listed in the performance section of Fullsizechevy.com, and get the open throttle body spacer and adjustable fuel pressure regulator and pressure gauge setup from CFM-Tech.
I am using a cam thats a step above stock, but does not require any programming, and my Burb climbs steep hills with ease.
Its the Comp Cams PN 12-388-4
IMO, Magnaflow's long case mufflers are a wonderful choice for these older SUV's.
Links:http://www.fullsizechevy.com/forum/general-discussion/performance/76859-tbi-mods.html
www.cfm-tech.com
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
What kind of performance do you want?
mybabyk5
Colorado Springs
i do have a tbi spacer but i will have to check the website, I didnt know I could mod the tbi
mybabyk5
Colorado Springs
has anyone purchased the aftermarket holley tbi from lmc?
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I was interested at one time, but not after seeing the price to get one from CFM.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Jim, do you pass the smog test ok with that cam?
Jims86
Patterson,Ca
5.7 TBI
I wouldnt touch the holly...it expensive, and they leak...just like the edelbrock.
The CFM-tech spacer has an opening thats like a crossover, allowing the engine to take full advantage of both barrels.....kinda sorta like a bigger throttle body. If you mod the engine enough to require a bigger throttle body, find a 454 throttle body at a wrecking yard, and rebuild it, but you will need to open up your intake manifold barrels to 2" each.
Try to optimize what you currently have, no need to spend money on something you may not need.
Jims86
Patterson,Ca
5.7 TBI
Yup!
all the swaps/mods I do, are centered on passing CA emissions in the enhanced smog check II areas.
mybabyk5
Colorado Springs
Thanks for the help but just for some info...at where on the holley tbi or edelbrock do they leak? Gasket? fuel intake fitting? You would think for the price they would be cherry. Thanks much for the help
Jims86
Patterson,Ca
5.7 TBI
The ones I have seen have something similar to a distributor hold down bracket holding the injectors in. The Rochester Throttle bodies cant tbe beat. Another thing, I think you have to modify your wiring harness to use those aftermarket throttle bodies, and if you ever have an issue with one, you dont have to special order and wait for anything, you can go straight to the local parts store or GM dealership.
aftermarket
GM
redneckgames
