Doppleganger
- May 24, 2019
- OH-MI: Just like it sounds
- Chris
- K20
I'm adding them to mine and did a practice run for accessibility. That void is small but the wires are, well - smaller. Not as bad as it sounds. The set I'm running (I think these are the GMT400 style?) have 2 small holes for the lamp and then a larger hole in the middle for the bulb fixture. I have a length of 10ga primary wire in white (visibility) I use for fishing wires and it goes pretty quick.
I'm considering making a hole inside (3/4" maybe?) for access if need be to each lamp. Close it up with a grommet - then under the headliner. Just a thought.
