cab bushings
Supersoaker
Littleton nc
Donnie
6.0 ls
Hi all .. I'm trying to find cab and core support bushings . 77 c10 stepside
I think the front cab and rad core support take the same and rear cab are different .
Looking for all 6 in rubber can any help and best place to get them
Thanks
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I haven't heard anything bad about these. You can just get the cushions and not have to buy everything from here.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=16
Supersoaker
Littleton nc
Donnie
6.0 ls
thanks i'm looking for the kit
1973c10
Don
I used the Energy Suspensions kit
it works good
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I just got a polyurethane set from energy suspension for my suburban. I like what I see, I'm going to install it soon. I couldn't find a kit that had ALL of the hardware necessary.
77scottsdale1
Scipio Indiana
michael
k20
Summit sells them. I think at 50.00 bucks. Close to that range.
77scottsdale1
Scipio Indiana
michael
k20
Scratch that, they are 20 dollars more expensive than they were a few weeks ago, but I found you some.
https://www.google.com/aclk?sa=l&ai=DChcSEwijjYTg1obSAhUCbn4KHb5NCokYABAD&sig=AOD64_2S3Iz6Rv7cC3o0tvUS1T2miY9QKg&ctype=5&q=&ved=0ahUKEwjOs4Dg1obSAhUXHGMKHZGlAhgQwg8IIA&adurl=
Supersoaker
Littleton nc
Donnie
6.0 ls
I here that the Energy Suspensions one ride harder and squeak . anyone having that problem ??
74 Shortbed
The Urethane is not as soft as the rubber but will outlast the rubber a 100 times, myself I've never heard cab bushings squeak just suspension bushings, but only if lube is not applied at installation, you can put lube on the cab bushings too to be on the safe side..
Camar068
10 yrs Air Force
i've had good results from Energy Suspension as well. Highly recommend. Get the part number you need and check RockAuto (we get 5% off) and amazon for prices.
Supersoaker
Littleton nc
Donnie
6.0 ls
sounds good :) :cheers: will order them and there like 1/3 the price :party36:
PrairieDrifter
North Dakota
Mason
Yup just a little grease at installation gets rid of it. But since there isn't much movement happening with the body mounts, unlike the suspension, they wont squeak much at all
77scottsdale1
Scipio Indiana
michael
k20
My dad ran them on his and never had a problem with them squeaking
Supersoaker
Littleton nc
Donnie
6.0 ls
Thanks All ... just put an order in at rock auto
spartantx117
