Brackets brackets brackets.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Needing several brackets for my 86 4x4.
AC brackets
Power steering brackets
Sway bar and brackets
Headlight harness too possibly.
Let me know!
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Located in central Oklahoma too btw
yevgenievich
Viktor
sad
very sad
less sad
I have headlight harness. Also have brackets from 87 firebird.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Should all fit then right? Where you located?
yevgenievich
Viktor
sad
very sad
less sad
Central Texas here. Shipping would probably make it not worthwhile on the brackets. Headlight harness should be ok. 87 Firebird brackets mount everything in essentially same place as v belt squares. @HotRodPC might have some and he is closer to you.
square:
vs f body:
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Yea I was hoping he would see this post. I lost his number when I got a new phone lol I'm just trying to avoid ordering them from LMC at a ridiculous price
Swims350
Logan WV
none
I got a serp. bracket setup for sale.
I don't think I have any to spare that I recall. The ones I have will be needed for the K10/20 project's engine.
Serpentine set up would be nice, but then you have shipping and I don't think all those brackets will fit in a USPS Flat Rate box, not to mention, you'd have to change water pumps too since the spin direction is opposite of V Belt set up.
Swims350
Logan WV
none
that's why I have it all, sbc water pump and clutch fan for serp. setup, alternator is junk and the ps pump just needs the flow valve fitting swapped from the current pump as it now has an IFF fitting on it and not the correct o-ring for 80 or so and newer pumps. Super easy and simple to do. I even have the ac compressor but not sure if it works as the system had no freon in it. the only thing missing from mine is bolts and I know they are around here in the garage in bolt bins.
and no it definately will not fit in a flat rate box due to the fan and brackets etc. I would guestimate shipping to be something around $50-75 just due to size and weight because it's not light when it's complete.
I even have a good tensioner and new belt for it.
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Well let me know if you find any to spare HotRod..
How much you asking Swims?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I have the ac bracket that attaches to the top of the block , that curves over the top part of the ac compressor if you still need one. Its off my 87' 350 small block motor
JRandle
Verden, OK
Jesse
Chevrolet Silverado
smoothandlow84
Steve
Devilthe0ry
