brace cab for removal
curse
49002 portage mi
kyle
I was thinking about removing my cab and media blast it to see what i'm working with. It has been repainted and am sure some body work has been done but no clue to what extent. Would bracing the cab to remove be a good idea or is it only a good idea if doing actual repairs?
Snoots
Roger
Jimmy Sierra
Get help and always think SAFETY!
When you get to be as old as I am you really start hating to see your friends buried.
Big Chip
Michigan
Kevin
C35
You shouldn’t need to brace it to take it off the frame. If you start cutting up to repair you may need to though.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Floor and structural work require bracing. As long as it's not being manhandled rough or bouncing around a bunch on a trailer it won't need bracing.
Would recommend setting some type of cribbing in the spots where the cab mounts. Don't just set it on the ground. Wouldn't take much to build a little cab dolly, some square tube and some caster wheels and a one night project.
I've always lifted them off. Keep the doors closed, windows down and put straps through the cab and lift it. Then you don't need any bracing. I've never have a problem that way.
curse
49002 portage mi
kyle
Thanks for the replies, good to hear. I don't want to brace it...yet
78ALB
