PrairieDrifter
- Dec 28, 2014
- North Dakota
- Mason
- Suburban k10, bonanza k10, c30 C&C, c10, gmc 1/2ton
- 350, 350, 350, 350, 350
Ok guys, I got my suspension lift in and i've been working on the body lift. I got all of the bolts broke loose except for two(4 actually) the two in the rear should come off just fine they're just in a crappy spot.
The two I have problems with are right behind the firewall, i figured if i had problems i could just access the nut right above it, so i pulled the carpet back and wouldn't you know, there are no nuts there. I'm guessing they are inside that floor pan support. The nuts aren't spinning, its just ridiculously hard to turn the bolts even with a big ass breaker bar, and that's quite a bit of bolt to turn out and i'm getting tired of it haha. One question i have is how are they mounted in there? Are they just tack welded to the body or do they have some kind of special nut?
I'd like to cut it out or something, other than continuing to wear myself out every time i touch it and get more and more frustrated... I've been soaking the crap out of it with pb blaster.
Any tips or tricks on those two? If not ill just keeping prying on the damn things
