Body molding
Scott91370
Burleson, Tx
Scott
Sierra1500
I'm trying to find this chrome molding so when the two tone paint is done there is a separation between them. All I can find is the single straight. Anybody have a link/lead?
Thanks!!
The front fender contours are different where that trim lays.
FireTruck1984
Michigan
1984 and 1984
‘81 thru ‘87 two tone has molding only
at the bottom of the paint separation, top is usually defined with a stripe
80BrownK10
Greenwood, SC
Nate
What he said.
Scott,
The front fenders are different. 80 was the last year of the buldged fenders as I call it. 81-87 has fenders that return to the front instead of that contour that follows the curve of the trim. Look close at the two fender styles infront of the wheel well to the front of the truck and you will see what we're talking about.
80BrownK10
Greenwood, SC
Nate
Looks like the paint also runs higher up on the body than the first Gen body and fenders.
Yep, they did. Then the paint line moved back down to the body crease for the '89-'91 Suburbans and K5's.
Scott91370
Burleson, Tx
Scott
Sierra1500
Bummer. I really don't like the way the 81-87 is done. I think if we stick with it a stripe will be done all the way around, maybe in charcoal to match the interior.
The quote wouldn't put the pic inline so I had to copy the url but here I do see the difference...
81-87 Fender
73-80 Fender
Thanks for everyone's input.
calredneck
Cailf.
Kerch
I am going to cut out some of the front of the 81 to 90 that is different and weld in a 73 to 80 part of the fender now I can run the early side trim and still mach the hood and grill.
Scott91370
Burleson, Tx
Scott
Sierra1500
That's way too much work for us and I definitely won't pay for it to be done, but it will look good! Post pics when done.
That's going to be more involved than you realize.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
73-80 Fender
81-87 Fender
For reference and those finding this in the future these pictures are labeled incorrectly. They are reversed, 2-tone gmc is the newer style 81-91 and the solid blue is the older round eye style 73-80.
Indeed, can't just cut it in half and splice together. Area around lights (both), lower section and the mounts are different between them as well.
Scott91370
Burleson, Tx
Scott
Sierra1500
You are right and I have corrected it in the original post.
jamba
Ruhtinansalmi, Finland
Jarmo
Blazer K5 Silverado
6,2 Diesel
One guy just offered a pair of -76 front fenders to me. Do they fit to my -82?
ali_c20
Austria
Alexander
C20, K5
No, the hood hinges, radiator support, Bumper, grille, moldings headlights etc. are different. The swap can be done but it's a lot of work.
whythoughs
