Body lift
Ypsik10
Ypsilanti mi
Chad
Looking to make cheap body lift cab only my truck has a custom flatbed .. What to use ? Hockey pucks? How far can I go without other problems? Only reason for this is I am making a custom winch mount behind the bumper need an inch or two.. Will I run into steering column/ shift linkage issues?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I used some 3" aluminum round stock and cut it in to 2" wafers on top of the factory body mounts with poly inserts.
Ypsik10
Ypsilanti mi
Chad
Any issues with this setup at 3" inches? Any other modifications needed?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Mine are 2" thick 3" diameter. With 6" suspension lift I only did 2" body to have room for my exhaust to fit over the frame, make it easier if I have to pull the trans and make the fuel tank swap easier. Don't forget how ever high your body lift is that's how high you gotta lift the bumper too because gap looks like hell.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
With the 2" or higher, you will need to extend the gear shift linkage between the steering column and the transmission. Make sure to loosen it prior to raising the body, otherwise you'll blow apart the shift tube inside the column and be in the same predicament that I'm in with finding a replacement column.
2" body lift on poly bushings puts the front valence lip almost level with the top of the stock bumper.
You'll also have to modify the fan shroud, since the fan will be 2-3" too low and will more than contact the shroud. You'll either have to go with electric fans, cut the shroud but deal with loss of air flow, or drop the radiator to match the engine.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I'm using a floor mounted shifter an I made a spacer for the bumper and reworked the brackets. Looks like normal. The rear bumper(Blazer) matches the body lift as well I just made all new mounts for it.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Cable shifter instead of hard linkage?
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
You can make your own lift pucks or buy them. I wouldn't ever go more than 1". If you actually work your truck, like off roading, the cab will soon enough begin to squirm around on the lift blocks and well, you don't want that.
Hockey pucks eventually crack, and then they fall out... and that won't make you happy either.
highdesertrange
kalifornia
mike
k30
I agree with shiftpro 1 inch max for a body lift. if you are making your own winch mount it seems to me you could design it without needing a bodylift. highdesertranger
iamberttt
