Big block chevy build, 489 stroker
Another worthy thread I've missed. Being a tall deck, out of curiosity, why did you choose only to go 489? I have a feeling I know why, just wondering if it's for the same reasons I would.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’d say to keep some steel in the cylinder walls
Oh you can keep the steel in the walls, just go with a longer stroke to increase even more cubes. My preferance would be to keep the rotating assembly lighter, less clearancing the block for crank throws. But the biggest reason is to keep the bore x stroke as squared as possible.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Tall decks have a wider rail 4.5” with very minimal work.
kellerbm
US
Brandon
427 tall deck
Like kong said, didn't want to waste the block if something went wrong.
Sent from my SM-T710 using Tapatalk
kellerbm
US
Brandon
427 tall deck
Cylinder heads came in, have to send them out for a valve job. I put parts that i ordered to make sure everything fit before I sent the heads out.
kellerbm
US
Brandon
427 tall deck
My tall deck block is an original 427 truck engine. I did have to shave some metal off the bottom of the block for the crank to fit and that was 4.25 stroke.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
What year? I believe they changed the pan rail at some point.
I was referring more to the stroke, not the bore. I get that part. I'd have done the same. I bore as little as necessary always. The few cubes you get by another .020 or .030 isn't worth loss of another use if needed in my opinion.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Most tall decks you can safely go .100
kellerbm
US
Brandon
427 tall deck
I can't remember the number on the back of block, but I'm pretty sure it went from 70-84
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Gotchya mine is an 86 I’m planning 4.5” stroke when I do mine.
kellerbm
US
Brandon
427 tall deck
Probably but you're also looking at spending a lot more money, if this engine was going in a chevelle or a nova than I would have gone with boring the block out more. For the build I want; this engine is perfect, still runs on pump gas and will be pushing about 550 to 600 hp
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’m with you on that.
kellerbm
US
Brandon
427 tall deck
In my opinion I don't think you would get much more of a gain from a 496 compared to a 489. To many variables on what you want out of the engine. Style of piston can change the compression ratio as well as rod length.
DamnTexan77
