- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
I was told not to. I used the old ones-
It was my understanding that adjusting that inner sleeve is part of the installation process. Are you using a manual or winging it?
I'm hoping the dam rag joint is whats causing all the play in the steering.
Did you check the joint at the column? What about the mounting screws inside the column, they good?
Has anyone ever read this???
http://www.moogproblemsolver.com/_pdf_alt/MOOG_PS_Bulletin_25888_K8194T_En.pdf
I like the new position of the grease fitting. Just wonder if that creates a weak spot though....
