Bad gas?
J Knight
Baytown TX
82 Chevy
350ci
The gas in my tank is at least 1 year old. I hadnt planned on it sitting that long. How bad is 1 year old gas? I feel like I should drain the tanks and put fresh gas in. Thoughts?
Unless you'd put some kind of stabilizer in it or something before it sat then I'd probably play it safe and drain it and put fresh gas in it.
marks86
Latham, NY
Mark
12v Cummins
I agree years old gas has caused me problems before
SlickGTP
Houston, TX
Had this happen when I was rebuilding my engine... I cut it with some fresh 87octane and was fine. How much do you have in the tank?
I'd think if you could at least cut it with equal parts, stale and fresh you'd be alright. If you can do more then even better.
J Knight
Baytown TX
82 Chevy
350ci
I think its got about half tank.
DREAMER
Baytown, tx
Dreamer
High Sierra
Bad gas?...I'd stay away from the burritos for awhile...LOL
I'd do what Slick said. Add premium fuel
Konas new ride
Alberta
Gerald
Any hints on this? Does a guy need to drop the brackets to pull the tank? I need to remove my passenger side tank.. :shrug:
If I remember right (it's been a decade) you had to undo the straps and everything to get the tank down
Konas new ride
Alberta
Gerald
I crawled under there.. by the looks of things your right.. I will be honest.. I was hoping for a easier solution... :bawl:
Haha...it's honestly not a terrible job if my '77 is the same as your '80. Be sure and spray a bunch of penetrating oil up there leading up to the day of the job, though. Should make it easier.
Konas new ride
Alberta
Gerald
:) over the course of today i used a can of weasel piss on everything.. Tomorrow may be the day for dropping the tank.. After i get back with the drive shaft and install it.. :party36:
SlickGTP
Houston, TX
I've dropped the tanks before by just leaving the straps in place and taking out the bolts for the brackets. If you're re-installing the same tank it also makes it easier to put it back in as you don't have to realign the straps on the tank.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
x2. This is how I do all my tanks. I just support it with a jack and a board, and then unbolt the brackets and down she goes with a turn of the jack handle.
You guys are just much smarter than me :D
Konas new ride
Alberta
Gerald
Thanks for mentioning this..
Thanks for confirming this...
Your not alone... I was looking at it wondering how to do it the easy way.. Hey.. Learn something enw every day.. :party36:
aaron06
