Back again fellas
fowjacob
Lubbock,TX
c3500
383 Stroker
Well I'm back again and sorry I haven't been on in a long while I had some stuff come up. I was planning on a 4x4 cummins swap for the square but I knew I wasn't gonna have time and had to have something to drive. so I had to sell the ram and bought a new one.
But now something else has come to mind my mom bought a 06 trailblazer with a 5.3 and totaled it the next day. Now I'm planing on swapping the lh6 (I believe that's what it is not and lstech) into the square. I have the whole car and plan on making the harness myself.
We have one problem tho. She was driving down the road the other day and it just died pulled the code crank sensor and no spark. Replaced it but when I was checking for spark I messed up #3 spark plug wire and figured the car would start on 7 if it was the sensor. As I tried to start it up it back fired once, white smoke came from under the hood. Second time it kinda started running then just locked up. So what do you think? Rebuild in my future? It was running just fine before it died so idk.
Sorry for the long post but just wanted to know what yall think. Probably be faster to go to and ls forum but I'm sure there's a tech or two on this site so why not. Plus I like you guys. Glad to be back!
fowjacob
Lubbock,TX
c3500
383 Stroker
Bad new started to take the spark plugs out of the lh6 to see if she would turn over and found a melted spark plug and the motor still wouldn't turn over! What should I do?
fowjacob
Lubbock,TX
c3500
383 Stroker
Yeah there are several actually. My favorite is flamingc10 but there are several more that are nice as well :) I was hoping to tag a bunch of people and get some folks to help ya out :)
fowjacob
Lubbock,TX
c3500
383 Stroker
I appreciate it bud! Miss being on here! Miss driving my truck even worse
firebane
Calgary, AB
Curtis
That is going to require a teardown unfortunately. A melted plug could mean internal damage to pistons or possible detonation problems.
fowjacob
Lubbock,TX
c3500
383 Stroker
I figured that. Well the thing is it back fired like a mother before it finally lock! I thinking it might have head gasket problems to because there little bit of water and the oil and I know it's got hot a time or two. Do these heads warp easy?
fowjacob
Lubbock,TX
c3500
383 Stroker
From what you are saying, what makes you think you did easy?
Not really anything I did just compared to let's say a cast head? But this car got hot once or twice 260+ I wasn't driving mom was
firebane
Calgary, AB
Curtis
Aluminum plus high temperatures is never a good combination.
You will need to straight edge the block and such to check for any warpage.
Damn, I have only seen that one other time in my life. It very well could have just been a bad plug. How old were they? Doesn't really matter, your going to have to pull the motor apart, and find the missing pieces of the plug.
The one other time I have seen something like that, my buddy was racing and way over revved the motor, to almost 10 grand, the only thing we could come up with, it the piston hit the plug, and shattered the electrode, we tore it apart and found a bunch of spark plug in the cylinders.
fowjacob
Lubbock,TX
c3500
383 Stroker
This one is like melted tho looks like the end of tungsten rod
One of 2 things, either a defective plug, or extremely hot combustion chamber temperature. How do the other plugs look?
krogers98gmc
