Axle Rotor Wheel Fitment
hillbillywillis
Arkansas
Karen
Have a 85 C10 and replaced the rear drum brake to disks. It's a 30 spline axle and now that we have done the disc brake conversion kit, there is only about an 1/8" that the wheel sits onto the axle. Is this normal or should the wheel hub stick out further. Not sure if it's the axle that supports the wheel or the the wheel studs. We are going with aftermarket wheels. Sorry if this is a super basic question, but it's my first build.
yevgenievich
Viktor
sad
very sad
less sad
Studs hold the wheel. Axle flange does not matter for holding the wheel.
hillbillywillis
Arkansas
Karen
Thanks, so how much do we need to actually need to support the wheel? Below is a pic of our setup, so you can see that there isn't much that would support it.
yevgenievich
Viktor
sad
very sad
less sad
Sorry. Missed typed the does not in previous reply. You should not have an issue. Gm wheels are not hubcentric
toneskeyz74c10
Colma, Ca
Tony
Hey There, I know this was an old post but I was curious to see what the end result was. I am currently in the same boat with aftermarket wheels. I was afraid that there was not enough center hub/flange to support the wheel because I was under the impression that it was hubcentric.
yevgenievich
Viktor
sad
very sad
less sad
A wheel that uses a conical lug nut usually is not a hybcentric. The lug nuts set the center.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
83sbc
Houston
C1500
Dose any one know what axles I can get that will be 30 spline and fit a stock 83 gmc rear end I believe my stock axles are like 30.75 inches long some one plz help urgent
I responded to your other post too, I'm fairly certain it's 88 models up are 30 spline. So you'd have to get them from a Burb or 2wd Jimmy or Blazer to get the 5 lug you asked about.
1987R10Man
