- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
If im not mistaken don't the 3/4 ton 4 door burbs use 1 ton frames? If so should be a direct replacement... i hope.
Nope, 3/4 Burbs has 3/4 frames with the usual 1/2 and 3/4 rear perch spacing.
However I believe 3/4 ton C20 crew cabs did have a 1 ton frame and rear perch spacing. Besides that, only 1 tons had 1 ton perch spacing.
