Auxiliary Spring Bracket
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
I'm looking for some general info on them. Ive got one missing on the drivers side and ill be hitting the yards on thursday for a replacement.
74 GMC 3/4 ton
highdesertrange
kalifornia
mike
k30
not really sure by what you mean auxiliary spring bracket. highdesertranger
Ditto !!! I don't get it either.
Are you maybe talking about an overload leaf spring bracket? Those aren't factory if you have them. Not that I'm aware of anyway. :shrug:
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Are you referring to the piece that holds the plies together?
The heavier rated trucks often had a rear overload spring that would contact brackets that were riveted to the frame. GM used them on our trucks just like other models.
Craig 85
Nashville, TN
454/TH-400/NP205
Probably these. Usually they're on 1 tons.
highdesertrange
kalifornia
mike
k30
I have only seen the factory ones on 1 tons and he said he had a 3/4 ton. highdesertranger
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
Yeah those craig. I have 3 on my 3/4. Missing one. Ill get pics soon. My truck came with heavy duty springs from the factory.
B.K. Cunningham
Spokane, Washington
Bryan
25 Hundred
highdesertrange
kalifornia
mike
k30
those appear to be aftermarket they don't look at all like my factory ones and the one that is missing doesn't even have the holes in the frame for a factory. also mine are 2 piece the bump stop piece and a reinforcing bracket that mounts under the frame and the bump stop mounts to the frame and the bracket. highdesertranger
highdesertrange
kalifornia
mike
k30
correction I just looked and there is only the bump stops no other bracket and the stops mount into the fame with 4 rivets. highdesertranger
Yeah those are aftermarket. Although they function the same as the factory setup, so a factory bracket could be used. Might take some hole drillin'.
jodygraham64
