Aunt Fannies Old Air Products
Oaasport
Justin
Suburban V10
Old Air Heat, AC and defrost system install for Aunt Fannie! NEVER AGAIN! Its really not bad if you dont mind mockup, drill, mock up, drill again, mockup then drill again. So i got the condenser mounted in its final location. Had to drill holes and mock up. Firewall plate is mounted and in final position. Black box behind glove box hole is evap/heater unit and is just mocked up at this point. This is just one half day worth of work and I will update as i come further along. Thanks for looking at my project and as always ask questions, post comments!
dvdswan
Port Orchard, WA
Dave
So, out of curiosity, how much was the difference between that and the original R134 setup?
Oaasport
Justin
Suburban V10
@dvdswan my truck is a 1982 so it had R12. I did this because I got tired of the vacuum actuator always failing and I also wanted a heavy duty Sanden Compressor conversion so I did it all at once. Out the door and I am about $1500 in but virtually everything is brand new. new ducting, new heater core, evap, electronic mode selector, drier, condensor, wiring, basically everything that involves heat or ac lol
dvdswan
Port Orchard, WA
Dave
That's not bad for a newer setup. As I said I was just curios. I have debated with myself several times with using factory parts of R134 systems and updating the compressor. Its just the system always goes back to the vacuum issues.
Thank you.
roundhouse
atlanta ga
justin
77,78,79,80 ?
I recently installed the vintage air in a 76 K10
Wasn’t too bad of a job although you do have to mock it up a couple of times before the final install
Blows ice cold air when you’re done though
MikeB
North Texas
Having installed three Vintage Air units (two older ones with cable controls in a 69 C10 and 55 Chevy car, and one Gen II electronic control system in a 37 Chevy), I would probably go with Old Air for my non-AC 82 C10. One of the reasons is Old Air doesn't run the hoses into the passenger compartment. Also, I'm not a fan of the flimsy V/A control panels with very tiny (22-24 gauge?) wire that's an accident waiting to happen. On the 37 Chevy, we had to replace the control panel, as well as the electronic control module before we ever even fired up the car. Also had to replace that very same type panel in another friend's car. (Fool me once...) I will say their tech support is very good.
As far as your "Never again" comment, what would you buy next time? I'm not sure any of the aftermarket systems would require less work.
BTW, my V/A "Direct Fit" kit took me 3-4 days (20 hrs?) to install in a 69 C10, so what you accomplished in one day is probably par for the course. Good job on installing the condenser, filter/drier, and lines!
Bhardiman1
