Anyone here done a long bed to short bed conversion?
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
I'm looking for a 87 model short bed truck to make into a weekend warrior..
LS2 with 4L80 trans with gearvendors overdrive. Short bed silverado in ok shape in my area are $5000.00 plus. I can find decent longbeds for $1500 plus all day.
So it got me thinking, it can't be hard to shorten a frame. Has anyone here done this? Or have any info for the steps involved? Looking for a stepside bed also.
bluex
Spartanburg SC
C15
Ya I've done it. 14" out of the middle. New rear brake line, parking brake cables, 16 gal gas tank and I think 5.75" off the end. I don't remember exactly I cut just enough off so the bed would sit down.
Have you ever seen the show Car Fix with Lou an Jared from muscle car? He cut one down on there an showed how to do it an keep 3 of the bed mounting holes so they lined up. Wish I had figured that out as I drilled 6 of mine an they are slightly off. The title of the episode was long an short of it or something like that.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
My 84 started life as a longbed, now a shortbed fleetside. I made the cut on the frame just behind the side gas tanks. Don't make a vertical cut when shortening the frame. I opted to cut staggered for best frame strength and it helps to ensure it will end up straight and even. I will look for a write up describing this technique since its a common modification these days from long to shortbed.
bluex
Spartanburg SC
C15
I cut mine straight an it's plenty strong an was perfectly even. No signs of any adverse effects from the straight cut an it's been done 11 yrs now.
smoothandlow84
Steve
Its far better to notch the frame then cut it straight, especially if you plan on putting anything in the bed. Reinforcing the frame with additional steel plate helps too. If you cut it straight and didnt reinforce with plate, then you're lucky. Cutting the frame at an angle would even be stronger than a straight cut.
J Knight
Baytown TX
82 Chevy
350ci
You want to run a 4L80 and a gear vender overdrive?
bluex
Spartanburg SC
C15
Of course it's reinforced, that goes without saying. I've loaded the truck down plenty since its been done with no issues. If an angle or step cut makes you feel better that's fine to. A PROPERLY welded an reinforced straight cut is fine as well an isn't the death trap everyone claims it is...
Reno81K20
Reno, Nevada
1981 & 1985
K-20 & C-20
350 4Spd & 350 Automatic
Nice info, Paul :handshake: Stacey David from Gears has done this as well and has vids on YouTube showing it. Very helpful IMO
highdesertrange
kalifornia
mike
k30
x2 on the 4L80 and the gear vendors OD. highdesertranger
bluex
Spartanburg SC
C15
If you go over to YouTube an search car fix season 1 episode 4 you can find the one I mentioned. After watching that I wish I had done mine that way. Its definitely the way to do it.
J Knight
Baytown TX
82 Chevy
350ci
That would make it and 8 speed, No??
Yes it would, I just was curious because your original post seemed like you you didn't know a 4L80 was an overdrive tranny. My mistake. LOL
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
With an LS2/3 I think it would make it more fun to drive :cheers:
I was thinking of a T56 MAGNUM, but i think there would be no traction. No slicks. Rear wheel will be 18/12.5 with a 335/30
You have a PM
Santor
