Another lift question
87silveradok20
Ohio
Levi
Silverado k20
How much of a lift do I have to do to fit 37s on the back of my dually. I am only talking the back here. I know I need 6 inches on the front but I want to run low pro 22.5s and still be able to pull our gooseneck trailer. I am thinking 4 inches.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
4inch with 1inch body lift?
75Monza
Colville, Washington
K30, K20, K20
are you talking a dually 4x4 square or rwd?
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Are you gonna run single rear wheels or duals?
87silveradok20
Ohio
Levi
Silverado k20
Dual rear wheels and I'm converting to 4x4
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I think your biggest issue will be the width of the wheels for the rear fenders.
My guess is you'd probably need around a 6" lift for 37's on the street and probably still need trimming as well.
87silveradok20
Ohio
Levi
Silverado k20
Do you mean them sticking out too wide? I like the look of them sticking out a little
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I meant more so the overall wheel well opening considering how the fenders tuck back in which would be your first point of contact with the tires.
Assuming you mean 255/70R22.5 tires, those are tall, but pretty narrow. Wouldn't really stick out all that much.
You may be able to get away with a 4" lift, but I'd be guessing closer to 6".
87silveradok20
Ohio
Levi
Silverado k20
Well I may just have to try it and see what works.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Yep. I say go for it. If it ends up needing a little bit more, no big deal. Just give her a little more height.
CSFJ
when sizing the tires, don't forget to leave enough space so the duals don't rub together. Doesn't make for very good tire life.
How or what type of lift do you plan on doing? I sure wouldn't plan on using 4 inch blocks or a shackle flip if I'm going to be pulling a 5th wheel or goose neck trailer. I'd suggest spring lift or nothing.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Your no fun....:signs6:
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
This is very important. You need expensive spacers between the rims. I say expensive because there are cheap imported spacers and the studs break.
Maybe this vid will be helpful...
87silveradok20
Ohio
Levi
Silverado k20
I was planning on 3/4 ton lift springs with airbags
djisurfli
