A/C vs Non AC kick panel vent door
Joshua Keith
Memphis
Joshua
I ordered a kick panel vent from USA1 Industries and what was sent appears to be the vent door for the non-a/c version. I also ordered the kick panel gasket and it came with a peel-off adhesive that was placed on the incorrect side. USA1 industries went 0 for 2 on this one. :/ Am I mistaken and the door is universal? LMC truck has the same exact part # for their ac and non ac trucks as well. Took 2 weeks to get here...hoping for some good news. Haven’t been able to find an aftermarket a/c version yet.
Here’s the vent left is the original, right is the new
https://imgur.com/gallery/gW9RYXM
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Guess I am confused- as far as I knew, factory a/c trucks don't have those floor vents.
Goldie does not - factory a/c.
Britt
Joshua Keith
Memphis
Joshua
Britt
Mine is an 85 so they must’ve put it in later on. There is only one and it’s on the passenger side. There’s a vent door opened by vacuum when the a/c is put on max air I believe. Beautiful truck btw! There is a post I found on hotrod.com but they didn’t explain how they converted the door over or how they connected the modulator to the door. :/
https://www.hotrod.com/articles/revamping-a-1985-c10-silverado-interior-with-lmc-truck/amp/
Joshua Keith
Memphis
Joshua
Yeah, yours definitely has one too. It’s behind that round pc of trim.
Craig 85
Nashville, TN
454/TH-400/NP205
@Goldie Driver you do have this door. It's behind the half circle dome in the right kick panel.
@Joshua Keith I bought the same items from LMC and had the exact issues. I was able to figure out the gasket, it was actually correct but it took 5-6 tries to get it right. The doors are totally different though. The non- A/C door has the flange on a horizontal plain and has the bar built in. As you can see from the picture, A/C doors have a hi-lo set up.
I tried to make the non-A/C door work by removing the bar that ties the flanges together, but I didn't like the working angles, so I cleaned up and re-used my OEM one (rubber was still good). The issue I had was the return spring was interfering with the arm above it. I was pressed for time getting my truck back together, but it wouldn't be too hard to make it work.
A/C Door
Joshua Keith
Memphis
Joshua
A/C Door
Man, I tried both! I boiled the old oem door and tried to straighten out the rubber edges( they were curled and dried up) but the new seal sealed up that hole so well. I had cab leak issues and wanted to prevent any water coming back into the cab. I’m currently redoing the flooring. You’re not going to believe this, but I’m using a zip tie right now to connect the modulator arm to the door and it’s working...hate it, but Its working
Craig 85
Nashville, TN
454/TH-400/NP205
I had an issue with water leakage at the bottom of the old gasket for the plastic kick panel. Due to being parked for 10+ years in the hot California sun before I got it, the gasket had totally dried out and was weeping water into the cab. The new gasket resolved this problem.
Turbo4whl
Downingtown, PA
Wayne
Try reversing the spring end for end.
Craig 85
Nashville, TN
454/TH-400/NP205
I had actually tried that. The problem is the two tabs you see here on the A/C version the tabs are in different planes. When you use the other style door, they are parallel and cause the spring bind. I'm sure a smaller diameter spring with the same tension would work.
Joshua Keith
Memphis
Joshua
Yeah, I could see how there would be a bind issue, but somehow this is working. I think it’s because the zip tie is able to bend when it hits the spring. Trying to figure out a better way to do this tho.
Craig 85
Nashville, TN
454/TH-400/NP205
I had removed the bar that ties the tabs together and used that one instead of the OEM rod you replaced with the zip tie. I had also reversed the direction of that screw on the pivot arm. If what you have works, I think I'd leave the zip tie. No reason to over engineer it. The only time this door gets opened is when you have the A/C on max.
Joshua Keith
Memphis
Joshua
Thanks for the advice! Don’t even have a/c yet lol Main goal was just to prevent leakage. A/c install happening in the spring
Use a coat hanger.
3dbello
