87 R10 guage cluster going crazy
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
the only thing that is working properly is my speedometer and volt gauge.
the fuel gauge sometimes show the correct amount but it twitches.
the temp gauge twitches between 210 and 110 it does not move slowly it move quickly. i use my test set on this and it hovers around 185 to 191 on temp
the oil pressure gauge bounces between 15 and zero and it twitches also. the pressure is 30 psi when i tested with a tester.
i just want to know what will cause the guages to act up on this truck.
oh and it's a fuel injected 305
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Intermittent bad ground.
Bad printed circuit.
Bad ignition switch.
Bad connection at cluster.
I agree with retro, you have a bad ground.
I'm going to continue the repeats and say it's a bad ground as well. I've dealt with similar issues in the past and this is the cause the majority of the time...
jake wells
Can i be me?
jake
custom deluxe 10
were are the grounds located at? firewall,chassis,body?
i just need the locations of were they are at.
thanks guys.
--Jake
Hip 2 be square
The printed circuit has a large area that is ground for everything that needs ground. The wiring that plugs into the cluster has a few ground wires, and they all go to a 6 or 8 connector ground connector up above the park brake under the dash. It looks like a metal spider...
78ALB
