86 Chevy PickUp- Electric Windows not receiving power.
Cyn88
California
Cynthia
New Motors
New Switches
Fuses Good
When I bypass the system and supply power for the motors directly from the battery they work just fine but when I try to use the switch, nothing! I know it could be an electric/wiring problem but I just wanted to check here first to see if I maybe I'm not overlooking something simpler/cheaper.
*Please note : This started when the driver side window was lowered all the way down. They have both been stuck ever since.
I've always had a problem with my driver side window getting stuck when placed either all the way down or all the way up, however I was always able to get it going again by removing the door panel and giving the motor a few hits with a broom stick.
Any/All help would be much appreciated
thank you!
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
wiggle the harness going from the door frame to the door
every time I have ever had a problem with electric window it has been the driver door harness
even the pass window gets power threw the driver door harness
the wires flex so much every time the door opens and shuts they tend to break
joseph916
