'86 C10 temp gauge
79Scott
N37°20’26” - W77°40’34
Scott
C10-Silverado
305ci
Hey guys,
The temp gauge in my '86 Silverado stays pinned at max temperature at all times, I am guessing the coolant temp sensor is bad? Truck runs fine and doesn't overheat or anything.
Thanks
Dutch Rutter
Independence, Or
Joshua
What Brown said above. Usually if it's pinned at max your wire is pinched or grounded out. If it's hard zero then most times your gauge or sensor is fubar in some way.
By pulling the wire that'll tell us whats what, if it stays the same you have a grounded wire. If it drops then it's one of the other.
79Scott
Scott
C10-Silverado
305ci
Guys,
I pulled my temperature sensor (see pics below). The connector that is on the existing sensor is different than any of the replacement sensors I have found. Have any of you run into this? If so what replacement did you use? Thanks
bob seifert
missouri
bob
Thats a temperature sensor but not to you temp gauge. It controls the solenoid in you carb that its attached to. I believe to deliver more fuel at idle while cold.
79Scott
Scott
C10-Silverado
305ci
Dang,
Where is the actual temp sensor? I looked allover the intake last night and didn't see anything that looked like a temp sensor....
Dutch Rutter
Independence, Or
Joshua
Dang,
They are usually placed between cylinder 1 and 3 on the side of the cylinder head. See the circled area of the picture. It should have a dark green-ish wire (color fades overtime) connected to it.
Should be able to just unplug the wire from the sensor. If pulling the sensor there will be coolant behind it.
79Scott
Scott
C10-Silverado
305ci
The temp gauge is pinned at max reading (Actually is to the limits of the gauge) Replaced the temp sensor and no change. Followed wire to the fire wall and all is good. Short of checking the wire from the firewall to the gauge I assume the gauge may be bad?
79Scott
Scott
C10-Silverado
305ci
Hey Guys,
Just an update on this. Replaced the temp gauge and the sending unit and my gauge still does not work. Traced the green wire from the sending unit back to the fire wall and that all looks good. Any suggestions of what could be wrong?
Thanks
idahovette
Weiser Idaho
Perry
K20-K10
Check the circuits out with a continuity tester
F-64
nyc
mike
R10 lwb
5.7 tbi stock
What is the resistance between the green wire at the gauge and ground? Does it change as the engine warms up?
tnahaus
