84c10 to 84k10
Erie pa
Michael
Scottsdale c10
getting ready to do a swap getting a full southern frame from a 81-87 using my 2 wheel drive cab im getting my frame with a tranny axles wheels everything it will be rolling going with a automatic my thing is will my cab clear or no?my floors are pretty good shape so im not after cutting them up also going with a 4 inch rough country suspension lift to for my plow set up big thing is i need someone that can help me who did this before not just random answers im doing this swap to because my front crossmember is rotted out also what will i have to do for a title im in pa if that helps thanks
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The big concern is t-case clearance. The consensus here is that you either need to cut out the shorter tunnel and use the taller one from a K-truck, or you need a two inch body lift to gain the necessary clearance. @Honky Kong jr will know the answer to the registration question.
bigcreek
