84 Chevy P30??? Anyone know anything??
73c20jim
Tombstone, AZ
damn computer collapsed all my spaces making my formulas unreadable. That's 30 minutes of work down the drain.
deve05
US
Diego
305 C.I.
don't know if this helps any, but I use this for any gearing/speed questions I have.
http://www.grimmjeeper.com/gears.html
Bruh..... That tool is like.... [emoji2962] That's exsactly what I needed! Even though i still wanna learn the math behind it, but that's awesome! Thank you. According to that chart. With a t56 and 4.10 gears. On 6th gear i can cruise at 85 with the engine at 2150 rpm.... Thats not bad! For having 4.10
Sent from my Moto Z (2) using Tapatalk
SDJunkMan
Black Hills of South Dakota
Jeff
Need to know engine RPM.
Need to know rear end ratio. (To convert driveshaft RPM to axle RPM.)
Yes the differential is part of the equation, see above.
Edit - :oops: Oops, posted before reading the entire thread.
73c20jim
Tombstone, AZ
Better than doing it with a pencil.
There's even a button to click on that fills in the trans ratio boxes.
73c20jim
Tombstone, AZ
I saw that. Going to use this for my 2006 Rubicon.
deve05
US
Diego
305 C.I.
Yeah both of the websites posted are awesome. The first website is more gearing detailed, and the second website has more variety of tools like fuel injectors.
Zoomalot
Banned
Parksville
Randy
Silverado Shorty
350 Ram Jet
I believe the front pulley on a 366 and a 454 are NOT interchangeable due to size measurements.
4WDKC
Southern Florida
Kacy
deve05
US
Diego
305 C.I.
4WDKC
Southern Florida
Kacy
I dont see anything but do the math with the .64 overdrive gear using the calculator above.
WHEELMAN
HICKORY TAVERN SC
BILL
454 v8
454 is the same back to 1975 or 1973
But the motor home engine will have a RV cam in the motor for pulling
El_Peter_Pan_85
