83 c10 proportioning valve ?
john ward
UK
john
77-83 and inbetween
Is there any rubber parts in the valve as i have to replace all rubber parts in brake system as someone has mixed the type of fluids and lots of jelly crap.
I think there is? I can gut one to see...
john ward
UK
john
77-83 and inbetween
Hi thanks i have been looking at some diagrams looks like they have o rings inside but not sure, so looks like have to get a new one will try rock auto first..
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
My old one had o rings.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If you're talking about the combination valve, on my '85 they are cup seals and one face seal. Good luck finding them. GM says the valve is non serviceable and must be replaced as a unit. And, of course, it's NLA.
john ward
UK
john
77-83 and inbetween
Blue Ox thanks mate thought it may be problem to rebuild so ordered new one, and all new stuff for the rest of system not going to take a chance.
Lowered87
Oxbow, Saskatchewan
Adam
R10
I am redoing my brakes from front to back. I tried to service my proportional valve but could not find a kit. There are many different versions for sale, both OEM and aftermarket. I used an adjustable Wilwood combination proportioning valve because it allows adjustment of the rear brakes. With this you can use drums and then later switch to discs. It also allows having different sized brake lines in preparation for disc brakes. Wilwood also recommended residual pressure valves to make the brakes more responsive. Still installing so I do not have a report on how it functions. I will update later.
Wilwood combination proportioning valve part #: 260-11179
Wilwood residual pressure valves part #: 260-13706 and 260- 13707
michaelmarine53
