79 Trans am
Your buddy Andy sure did one heck of a great job!
Swims350
Logan WV
none
yes he did and as soon as I hit the lottery I'll have him come to stay, and we'll cut it up and put in new wheel tub, inner lower 1/4's and outer 1/4's along with a roof and tail pan area, and that pass. side rear frame area. I'll cut em out and get em ready and he can sit back and eat some chili dogs, watch tv and relax til it's time to weld em in.
Swims350
Logan WV
none
eh since I won the lottery might as well do mini tubs and cut the rear end down to run fat meats 4 link etc. some CE frame rails in back and subframe ties etc.
So how does the tip over jig work? Is it somehow balanced so you can tip it over by hand, or do you use a jack or hoist?
Swims350
Logan WV
none
it' s basically a set of wood legs to hold the car up in the normal position, but the ends you want to tip up or the side has a piece of plywood cut in a 1/4 circle, and braced upwards, that way you can lift the opposite side and it'll roll over on that plywood and rest on the upright, holding it on the side. They have a ton of them on youtube.
Swims350
Logan WV
none
wood and materials have been bought for the jig just gotta start building it. I have to rearrange those mining belts or mats in the garage so I can have jackstands on them as well as the jig legs land on them once built. I'm still working on cleaning the car out, I got almost everything out and put up now after 2 days worth lol.
Swims350
Logan WV
none
have I ever said I hate finding more rust? or always keep coming in and updating with more rust found?
Well same thing found it to be ate out around the pass. rear seat belt retractor in the floor, about 4-5 inches long and 1/2-3/4 wide. Another caulked over spot of course.
Now if I can get the dang stuck torx bolt out for it
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Here's an upside down Camaro I found in a field in Tennessee maybe that will cheer you up because your car has to be way better than this,
Swims350
Logan WV
none
more bad parts lol, removed the rearend today, and leafs etc. both leafs have the main leaf broke in two right behind the centering pin, about an inch or so from it. I also found out it's an open diff. for sure with 2.56's so looks like now I have to get another carrier to run some better gears like say 3.42 or so. I also wat a posi setup so looks like I have to fork out big coin for one later if I can come up with that much at once.
I bet a jig similar to that could also be used for tipping bodies right off of frames. I've got some brainstorming to do now.
Swims350
Logan WV
none
one guy even made an actual rottisserie out of wood only.
Swims350
Logan WV
none
Swims350
Logan WV
none
Swims350
Logan WV
none
rowdy_80
