78 crew cab electric issue
ddc456
Bend, OR
Doug
Chevy K30 Crew Cab
Trying to diagnose why the gauges will not work in the truck. These are the factory gauges and none are working. Where should I Start in trying to diagnose the issue?
Thanks
Doug
DavesJimmy
Jimmy
Fuses. :33:
Clutch
Dirty Jersey
K30 Silverado crew cab dually
L82 350
Nothing works in mine eather
Yes, fuses. If not, I’d check to make sure the cluster’s plugged in and my next suspect might be he printed circuit. Hopefully it’s the gauge fuse, and there aren’t any shorts.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Redball
Kerntucky
I6 250 4.1
I also concur that checking the cluster plug in and or the printed circuit sheet would most likely be your problem if none of your electrical controlled gauges are working.
SMC2224
