77-80 factory bucket seats foam question
1984K10Scottsdale
Stafford Springs CT
Thomas
Just picked up these factory high back bucket seats and console from a local yard. I want to restore them, my only question is who here has experience with seat foam? I need to replace the bottom foam on the drivers side and would like advice on what and where to buy. Thanks.
dvdswan
Port Orchard, WA
Dave
Nice find. Did you get the mounting brackets?
1984K10Scottsdale
Stafford Springs CT
Thomas
Yes. I have all the brackets, and center console. Just finishing restoring the center console up.
harcorshe
Denver
Sean
454/TH400/NP205/14b 4.10/Truetrac/d44 4.11/
Doing the same thing. Got the foam from Classic Industries. May have needed to search under K5 Blazer low back seats. They’re the same. Also replaced the zig-zag springs. Again searching under Blazer low back will give you more options for upholstery kits too.
Sent from my iPad using Tapatalk
1984K10Scottsdale
Stafford Springs CT
Thomas
Perfect. Thanks for this information. Worst case I am going to glue down layers of different density foam and mold it with a electric carving knife. The passenger side isn’t as hooped so that will serve as my template to get the height right. I got a bracket that needs welding and I will check on the springs when I remove the foam to see if they require repairs.
1987R10Man
