75 K10 distributor issues
Nastardly
Sacramento, California
Dylan
K10 Scottsdale, short box, stepside, part time NP205 conversion
I think I have it wired in the correct firing order, but starting with the wrong wire as marked by the previous owner.
74 Shortbed
You're probably off now, go thru the firing order again, starting at the post that the rotor is facing that will be #1.
Nastardly
Dylan
Is this correct? The wore connector deal and 3 terminals back is number one?
74 Shortbed
You can put #1 where ever you want but this is factory.
Nastardly
Dylan
Thank you. I don't believe my echlin from Napa is labeled. I'll check it tonight after work. Is the echlin any good? By the looks of it, I already need new plugs.
74 Shortbed
Sorry, I don't use Echlin so I can't really say, in fact I don't even use those retainers..
Nastardly
Dylan
Which retainers do you mean?
74 Shortbed
That ring on top that has the numbers on it, it snaps on top of the plug wires it's a factory piece.
Nastardly
Dylan
I didn't realize that was a separate piece from the picture. Very nice truck, by the way.
74 Shortbed
Thanks, the idea is to hold the wires on the cap, there's a snap on each side to hold it, it is a cool thing if you have junk wires because you can take all the wires off the cap and just put them back without relocating each one, but if you use good wires the retainer will pop off the wires before the wire comes of the cap, lol..
Nastardly
Dylan
Okay, I didn't get one of those with my truck when I got it.
74 Shortbed
That's because they usually get thrown away, when I got my Nova I was shocked to see one still there, lol..
calebrwalk5
