- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I see the point you're making Christian but many times lower rpms doesn't always mean the best efficiency. Keep in mind, the taller the rear gear is, the more strain you're putting on the rest of the drivetrain too. The more strain you put on the drivetrain does not always net best efficency.
About the best example of this I can think of is using a 10 speed bike. If you put the bike in a lower gear like 4.10s, you pedal faster but it pedals easy and you don't go near as far since you're actually moving at a lower speed. Then using a high gear, like 2.73s, you pedal much slower keeping your rpms down, but its hard to pedal and more strain on yourelf. This is the same exact principle as a vehicle rear gear and this is why lower rpm is NOT most efficient, and its also more strain on a 700r4 in both the hard parts and the clutch packs especially the 3-4 clutch packs that are notorious for burning up. In most cases, due to to tall of a gear ratio, or big tires.
I like to go low gears and have an OD to compensate the low gears to be able to cruise 75-80 at a reasonable rpm.
