6.2 and a 454 weight ??
V20 4X4
Iowa
Mark
V20
6.2 soon to be 454
How is a 6.2 Diesel weigh more than a 7.4 BBC ??? They are both made out of cast arn't they ????
I don't know how much more, but the 6.2 is heavier. I'd guess 100 lbs more at the most.
hirschdalechevy
norcal
rich
k-30
Complete I have read that the 6.2 is around 750lbs and a 454 is around 685lbs depending on what you have on them , I do know that with aluminum , head's , water pump , intake manifold and a mini starter and header's the 454 can get down close to a stock small block wieght.
:patriot::patriot::patriot:
I've heard that that the diesal motors have alot more metal in the webbing around the crank and cam bearing areas. Also, the 6.2 block dimensions are bigger too aren't they??
Sundevildaddy
Washington
Kris
K20 Camper Custom
6.2L (J)
The nominal weight of a 6.2 (J) is 700# +/-.
The nominal weight of the "W" block had a dry weight of 685#
They converted to Aluminum Heads (L71 - 427 // same Block, different bore) reduced this by 75lbs. Eventually, they brought it down to (in the ZL1 block // 427 / same core) to 575#. However, this was an all aluminum cast block and heads.
Current crate motors run in the 800# range (for 454s). Though the shipping weight is part of this, it is offset (only in part) by not (typically) including the Intake Manifold, Water Pump or Harmonic Balancer.
source: wiki & various crate suppilers
Just an FYI, another mind blower, the old GMC V6's outweighed Big Block Chevys.
Sundevildaddy
Washington
Kris
K20 Camper Custom
6.2L (J)
LOL ol' boy down the road has a couple of these sitting in his shop.. I swear they're used to anchor.. his house :evillol:
oooh.. how 'bout the other end of the spectrum?! the 270 Stovebolt?! lol.. I might strain a toe with it's whole 70#s
12turnda
